I got a new to me boat
floatfisher
Hi, I am new here. Been lurking for a while and made the plunge and bought a boat. I picked up a 1992 Spectrum 1706 with a 90hp Force out board. I have always liked the looks of the Spectrum boats and I found one on craigslist a little less than a month ago. Cant really find a whole lot of information on the boat or motor on the web. Would like to see a diagram of the boat, wiring, what hoses are for what, how big the fuel tank is.......
Well anyway, I took the boat out for the first time yesterday and could not start the motor!! The battery was charged but seemed to die off kind of quickley as I tried to start it. I am not sure but maybe there is a trick to starting it and I just have to figure out what the trick is:confused: I have heard the motor run 2 times before so I know it starts. When I bought the boat they ran it for a little bit so I could hear it run. It seemed to start right up but I am sure they had it warmed up so it would start right away. The second time was when I changed the plugs, I ran it for a few seconds with muffs on. I can not get the bulb hard on the primer buld and there may be a plug in the vent? As when I took the fill cap off the bulb firmed up a little.
I am going to post a topic in the Force motor area to see what the experts say. Thanks!!!
DAN M VAGOS
Re: I got a new to me boat
Did you try using the choke yours may be the push the key in or may have a choke button
floatfisher
Yes I have the key type choke, and I did try it. I thinnk I may have a cloged vent tube. I am going to work on that this evening to see if it help. I think I may pick up an extra external gas tank and new hose and bulb to see if I can get it to fire on that.
Thanks for the reply!
southkogs
Welcome floatfisher.
Was that the first time you've heard it running on the water? Runnin' on muffs on a trailer is a little different than running in the water. There's back pressure on the engine when it's dunked, and it's working "under load."
floatfisher
Thank you for the welcome!! Yes it was my first time taking the boat out to the water. I went out last night to buy an external tank and new hoses. I am going to try this out and see if it works, then I will know if there is a problem with my on board tank and/or hoses and\or vent, I think.
