I have a 69 merc 80hp
cdwilson
I have mercontrols for my motor. Is one of the cables for throttle and one for gears. How does choke work? I rewired the control with one of those six connection key choke type switches. Can anyone explain. Thanks.
cdwilson
Re: I have a 69 merc 80hp
Please somone help me. I am broke and gas cost to much.
MIKEY*2007
What Are You Trying To Do Exactly
cdwilson
Ok I rewired the ignition with one of those push the choke turn key ignition with the six connector on the back. I can turn the motor over after I wired it but have yet to start it. How do I check to see if the choke is working when I push I in and turn the key? I trying to make this work. Thanks!
MIKEY*2007
i have a 100hp same era sometimes the solenoid sticks so i can manually lift the choke on top of motor under the cowl by pulling the manual choke knob up and down also if you turn key on push choke button you will hear a click if choke works and the cables, one is gears and throttle in one, and one is throttle fast idle for warm up.could you send pics for id.
harry styles
The big lever is the gear shift and throtle all in one. The first stage is gear change then the throtle comes into play. The small lever on the right is the fast idle.
Hope this helps.
Muqwump
One cable is for the throttle and the other is for shifting. Do you have the model number of the Mercontrol?
Muqwump
Does it have a safety switch?
