elkhunter338
Master Chief Petty Officer
- Jun 27, 2009
- 818
Well I was really wondering if the foam under the floor was water soaked and causing corrosion so tonight I cut a hole in the floor inside the cuddy cabine to inspect the boat. I cut a 20x28 hole. What I found was the foam was not soaking up water, the spray foam was not soaking up water either.
However the boat was real moist under the floor because there was no way for air to circulate and dry out the bilge. There was no corrosion where the foam was touching the alum.
I now have a 20x28 access door and I plan to get some rubbermate containers so I can store stuff under the floor.
I would love a custom fit alum fish box, but that is not in the budget.
I plan to leave the hatch open to let air circuilate under the floor and dry things out in the off season.
