daydreamer1252
- Aug 7, 2007
- 212
for reference see previous post.....http://forums.iboats.com/showthread.php?t=511084
Thanks to all for the ideas I got it off now I don't know why I am looking at what I am......the pulling has pulled the outdrive and of course with it the drive shaft AND THE ENTIRE gimbal bearing..
How and why?
The gimbal shows no signs of damage or distress. The drive shaft shows no signs of damage either. No apparent damage at the gimbal bearing seat is noticeable. The first o-ring is inside the gimbal and is apparently stuck fast....tight enough to pull the entire assembly out with the driveshaft.....as stated in the previous post the drive would go on no further and was starting to damage the threads on the 6 studs and nuts when trying to draw it up....now all indications are that it was OK at that point.....
What is this telling me? Except that maybe I should not be doing this work. Any and all input is appreciated...Thanks all!!
How and why?
