makeshifty
- Jun 28, 2010
- 11
My boat capsized last spring when a vicious storm hit the lake that I keep my boat on. The entire dock broke loose and while slamming in to the next Dock my boat sunk
After 8 hours of pulling this 24' home made house boat back upright, I fogged the cylinders and filled the carbs with cleaner and let it all dry out. With little repair, new starter, solenoid, battery, rectifier and lots of cleaning, I managed to get the engine running strong. Then I rebuilt the rest of the boat and started using it last fall. After taking it out a several times and it working great, it randomly shut off. I cranked it over and it started then died again in a couple seconds. I checked for spark, and i had no spark on all 4 plugs.
A couple days ago I started to dive back into fixing it, in hopes of fishing this spring, but I cant seem to find the problem. I'm running out of test to preform. As far as i can tell, the rectifier and stator test good with an ohm meter, I've disconnected the black yellow wire from the power pack and cranked it, I've removed the red boot that connects the ignition switch and jumped the starter, replaced the power pack and still no spark. I pulled the fly wheel 2 days ago and cleaned the inside with break cleaner and wd 40 and I sanded the lil bit of gunky rusty stuff off that I found in it. I lightly sanded off the coils of the stator and greased them with vaseline. They looked a lil discolored but surprisingly clean and green. They do have 2 cracks with a dab of glue and 1 crack with no glue, but I've heard that doesn't effect the performance and the glue was factory. The sensor coils were pretty rusty so I cleaned and sanded them lightly, then coated them with vaseline as well. I tested the 4 sensor wires to ground. They all gave me the same reading, I'm not sure if there is a specific reading I should be looking for, but the consistency was enough for me to trust them.
After putting the engine back together, I cranked it over with no plugs in and had spark for a few seconds. I got excited and put all new plugs in, only to realize I once again have no spark on all 4 cylinders. After cleaning grounds and connections for a while I cranked the engine over and got spark which visually seemed weak, then stopped all together.
Today I checked for spark, had non and decided to re perform all the electrical diagnostics while getting no spark. with an ohm meter, the stator checks out correct, the rectifier is correct, and the sensor coils give me 4 identical readings....
Where do i go from here? Can fly wheels go bad? I'm at a total loss of ideas. Any advice would be GREATLY appreciated. I had a rough go of it this past year but I'm determined to get this old beast working right.
Thanks!
Thanks!
