Please note that the PICTURE UPLOAD function is not working. The iBoats Forum Moderators are working with the system administration folks at the parent company to get the issue resolved. This happened about a year ago and here we are again. In the meantime you can post photos as links to a picture hosting site of your choice. We are sorry about the inconvenience and will advise when the issue is resolved. Thank you for your patience.
Oh, I bet it's a thru hub prop too. I remember those darn things....yours is a 14 1/2 x 24 SSTR. Fits a V6 or V8 gearcase. Be careful if you try to run it.
I'm thinking with such a high rate of pitch that your engine may struggle getting up the RPM's, you may also find the boat faster idleing in gear making it more challenging to maneuver around the docks.
24" isn't all that much pitch. I could get around docks just fine with the 29 Mazco I ran on the race boat. Those props acted kinda funny on certian boats. I tried on on a Rabco I had once. The boat had no real issues if you stayed under 80 mph. We put one of those on and about 55 or so the boat went nuts. Basically out of control. Put the other prop on - 80 was fine. Put that thru hub cleaver on and same thing. Went crazy.
Just take it easy and be careful. It may be fine on whatever you have. I know it didn't like what I had.
according to my source for omc parts the prop is a 14.5" X 22 Pitch Propeller that firs the following applications:
Models: V-4(with V6 Gearcase)
100hp (1984-thru)
120hp (1985)
130hp (1995-1996)
140hp (1985); 140HP [25"]
1989-thru
Models:V-8
250hp (1991-thru)
275hp (1986-1988)
300hp (1988-1995)
3.6 litre(1986-1987)
Models: V6
150hp (1978-thru)
155hp comm. (1978-thru)
175hp (1977-thru)
185hp(1984-85)
200hp(1976-thru)
225hp (1986-thru)
235hp(1978-85)
2.6 Litre(1984-85)
here is where you can find there site as it is great for reference www.dougrussell.com
