Re: I need info on my Palmer engines
DIPSHIPS, One thing I forgot to mention, the early Safaries had fiberglass fuel tanks, which can be an issue with modern ethanol fuel blends. So before you think about sinking much money into yours you might want to check what kind of tank you have and its condition. A modern aluminum fuel tank replacement cost me $1500 plus all my labor to get the old one out, and mine was designed for access. with a separate deck cover section The early ones had a completely sealed tank enclosure the only opening was the little cover in the center to the level indicator. Which means break out the Sawzall and cut the deck out. Next thing check the oil in those old 270 outdrives, especially if it has been around saltwater, if it is clear they may have some value, but parts are not cheap for them. Any questions let me know.
