I need some expert helps on 1963 johnson super sea horse motor.
the_one
:confused::confused::confused:I have replaced impeller, carb kit. Engine is running but every time I throttle to fast speed Engine rep up as it supposed to do but in 30 Seconds on fast speed mode it drop down. By meaning once throttle is in fast mode the bower of the boat elevated up for 30 Secs and it flat out, parallel to water surface, this repeated constantly. As you can see I'm a beginner on this type of work. I really need your expert opinions on solving this problem, please HELP! I also have made some adjustment on the low and high orifices needle, I thought it doesn't have correct amount of gas/air mixture, but it seems like it not the case. PLEASE HELP.
Thank you so much.
Joe Reeves
Re: I need some expert helps on 1963 johnson super sea horse motor.
A 1963 what? There are a lot of Johnsons out there.
the_one
Sorry. 40 hp 1963 johnson super sea horse
the_one
Outboard motor
tashasdaddy
http://forums.iboats.com/showthread.php?t=167352. have you check spark when dies back, compression? are you sure the float needle is closing, if not closing all the way, the increase is rpms, moves fuel faster, and it could be flooding the motor, causing the drop in rmps.
