I need to know the timing setting for my engine
84EdH
I have a 1998 5.7 vortec longblock build using a 1995 Thunderbolt IV ignition, Edelbrock 1409 carb with a cast iron high rise manifold.
I have got the engine running by setting the timing by seat of my pants, it sounds pretty good. I would like to set the actual timing and don't know the correct setting.
Also, is the timing set a idle on this engine, or at a given rpm?
Ed
90stingray
Re: I need to know the timing setting for my engine
What does your engine cover say? Should be 8 degrees at idle. Then rev it a little to make sure advance is working.
84EdH
This is a new build of an engine. 5.7 vortec longblock, with carb and thunderbolt Iv ignition from a 1995 non vortec mercruiser 350 mag.....no "cover" i will try 8 degree and see how she runs....thanks
krisnowicki
I just built mine and it was a 2002 tbv set up vortec with the 2bbl and a bravo drive. The plate on top of the engine called for !0 deg btdc
