I/O transom replacement
jas587
Anybody have any tips on replacing a 79 Sea Ray SRV 200 transom?
JasonJ
Re: I/O transom replacement
Yup. Pull the outdrive, pull the engine, pull everything that is connected to the transom. Cut the inner wood out, glass in new wood, reinstall everything, and go boating. Be prepared to have to do the floor and stringers, they can be rotted too if the transom is rotted. Yeah, that was a bit simplistic, but that is what is done in a nutshell. Good luck....
jas587
Thanks for the info. Any suggestions on the best way to get the plywood out? It's probably bonded to the fiberglas with resin, isn't it?
qaztwo
just did a 76. A chisel and a grinder, have fun.
Originally posted by jas587:<br /> Thanks for the info. Any suggestions on the best way to get the plywood out? It's probably bonded to the fiberglas with resin, isn't it?
Click on Jason's link,.............<br /><br />I've been watching the transformation of the "Beast" for a Quite Awhile now,........... ;) <br /><br />BTW,.....<br />It's All in the Archives here at iboats,.............<br />Like BB4C says,..........<br />Do a Search,........
