I/O water pump question
Lucky Penny
has anyone ever removed the water pump from their I/O and just installed an engine driven water pump the same as a straight drive setup. the I/O pump setup is just another point of failure for I/O units.
Bt Doctur
Re: I/O water pump question
The water flow aids in cooling the outdrive oil
45Auto
What you are describing is the way a Bravo drive works. The water pump is driven off an engine fan belt.
The water will follow the same flow path through the outdrive no matter where the pump is located.
