I/O's vs Inboards
rickyp52
I'm looking to move up to a cruiser in the 30 ft range with twins. I currently have a 24 ft with an I/O that I can pretty much service myself. I would really like to go to inboards in the 30 footer, but I am hesitant as I know very little about them. How do inboards compare, cost wise? Are they high maintenance? Are repairs more expensive than on an I/O? Enlighten me please.
Chris1956
Re: I/O's vs Inboards
Ricky, Inboards are a proven technology. They are likely more rugged and cheaper to maintain than an I/O. However, if you run aground you are in deep dung. You can do extensive ($$) damage to the propshaft and other underwater components. Alternatively, the outdrive on an I/O will kick up if you run aground, hopefully causing little or no damage.<br /><br />I would base the decision on the average depth and composition of the bottom of the water on which you boat. I boat on a sand/silty shallow bay, with many fine places to run aground and channels that are 6' deep (on a good day)and shift alot. I therefore, will not run an inboard!
navigator336
I agree with Chris. Inboards will be cheaper to buy and maintain and will likely last longer. Props may be more expensive however if you need a new one. You will have a shaft, a strut, a prop and a rudder (x2 for twins) in the water vs. the outdrive and there is no trimming the drive up or down. If you use direct drives, the engines will be forward and generally be under the salon. If you go with vee-drives, the engines will be under the cockpit similar to I/O's. If you will rarely be operating in shallow water (less than 6 feet) I'd definitely go with the inboards.
Buttanic
I think good navigation is the solution to runing aground. Know what the draft of your boat is and set the offset on the depth finder to warn you when the bottom comes up to within 2 feet of your draft. With modern depth finders there is no excuse to run aground. Now if you want to run around in unknown waters at 40 MPH all bets are off.<br /><br />Buttanic
John Carpenter
Don't remember how many I/O's I've had, but several. My current boat is an inboard...26 yrs old. I've run it since 1997 and have not spent a penny on the drive train. Really. I would not be interested in going back to a stern drive.
swist
Yeah, this is a no-brainer IF you have the right conditions for a deep-draft boat. If I didn't, I would go with an outboard before any kind of I/O, which to my way of thinking are an engineering rube-goldberg. No matter how well they are built and maintained they seem susceptible to so many different problems.
salty87
of course, your expenses will go up with a pair of engines so i won't bother with any of that.<br /><br />maintenance is a snap...oil changes, belts, hoses, plugs...if you're talking gas and not diesel, this is as easy as it gets.<br /><br />repairs are straight-forward too. your underwater gear is a little more exposed since it's fixed in position but there are no moving parts and fluids exposed to the conditions like an i/o. no extra gaskets or reservoirs.<br /><br />inboards will suck more gas though. they'll also hold their value better.
