1990 VJ90TLESB, 90 Hp Johnson
I had my boat in the driveway with the muffs on, but forgot to turn on the water one time. It ran for between 5-10 seconds. When I noticed I stopped the engine and let it air cool.
I went on the water the next day and received the high temp alarm (steady high pitched tone). I shut it down within a few seconds and had Sea Tow take me back in. I didn't notice if the witness was spraying water or not.
I think my water pump was damaged due to the lack of cooling in my driveway from the day before. So, I want to remove the lower unit and take a look. In the forums I've read about all the hidden bolts that need to be removed and possibly a drive linkage. For my engine, I was wondering if someone could give me some pointers when I attempt to remove the lower unit. Is there a linkage pin that I need to remove? Is it under the carburetor? Do I have to remove the carburetor?
Do I have to worry about anything (melted parts) being stuck somewhere in the cooling system? Is there a filter/screen after the impeller than would catch debris? Is there another filter/screen that I need to clean? Can I retest the new pump in my driveway?
