Wave34
- Oct 17, 2017
- 341
New boat, so as preventive maintenance I decided to remove the outdrive.
I was expecting a dry bellow, but found a pool of oil. What is strange, is the the 2 U-joints seem dry, no dripping.
The week before, I changed the oil. Is it possible I filled too fast? I don't think, it took me almost 45 minutes.
The texture is like gear oil but the smell is not there, may be because it is new.
Also, I found an oil seal spring inside. Is it possible it is me that was not careful with the alignment tool that knocked something inside?
Oh, also there is like a spring wire inside the bellow, which seems out of it's groove. Is it used to hold the bellow in place?
The alignment tool is a Mercruiser one that I borrowed. There is a total of 3 steps. The one farthest from the handle goes in the splines, the second step, doesn't do anything, and the third step which is also the handle goes inside the gimball bearing. WhY they took the time to machine step #2?, why not left it the diameter of the first step?
Unless the Merc is different from the Volvo?
Inside the top bellow:
oil seal spring
ALIGNMENT TOOL VS DUOPROP SHAFT; STEP#2 NOT TOUCHING ANYTHING
INPUT OF THE OUTDRIVE, IT LOOKS LIKE AN OIL SEAL WAS THERE?
oil seal spring
