I removed the shift pivot screw, now what?
Waltsfastz
Like said not thinking I removed loosened the shift pivot screw, not removing it from the housing, thinking it was a drain. Now the unit will shift into forward but sounds rough and will not shift into reverse. How do I get it back working and what exactly does this wrk? Thanks
jerryjerry05
If you moved anything after removing the screw???
Then you'll need to dismantle the drive and put the shift yoke back in place.
Not a real hard job but not fun either.
Fill out the signature and tell us where your located??
You might be close to someone who can help?
