i think i blowed it up .... (with pics) m60b
levi_tsk
Ensign
ok so two weekends ago i had trouble starting my m60b but i figured out it was a dead battery .... but in the process i left the linkage loose on the bottom two carbs and since it ran fine off the dock i didnt realize it was like that until it was too late
compression was 105 0 105 when i got it home so i pulled the head and this is what i found :
on this one you can really see it
my question is about the groove in the cylinder wall i dont think thats sposed to be there or is it ? looks like the wrist pin broke freee of the retainer clip and wore a deep groove in it if so i know the power heads toast but if it IS sposed to be there what is it for?
this is the middle cylinder btw if that matters
levi_tsk
Ensign
Re: i think i blowed it up .... (with pics) m60b
DAMN!! oh well ... does anyone need any parts ? everthing else worked GREAT coils power packs trim and tilt its got a new set of control cables and the carbs have JUST been rebuilt lower unit shifts fine with no water leaks brand new water pump on that(including new housing prop's a 14p ss power tech pm me if you need something ..... id hate to throw all this away only to see another motor that needed a part go to the bone yard too
TOHATSU GURU
You can sell the parts and do fairly well. If you part it out, rather than as a junk parts motor, you will get a lot more for the individual pieces than what the value of the motor would be in running condition:)
levi_tsk
Ensign
yeah its in pieces already and thats how i planned on doing it
thank you by the way for the help on this one
you dont know where i might could procure a new power head do you?( that option is still on the table)
TOHATSU GURU
The engine has a top value of less than $1200.00 in operating condition. A new powerhead would be a lot more than that.
levi_tsk
Ensign
i figured as much .... ive got a line on a 90hp yam 3cylinder to replace it so i think im going that route for now the next will be a 60 etec
