I think i found out why it stoped
Simple_Man
On the Fourth of July I was out for a cruise, and the motor just stopped. It wouldn't turn over, and I couldn't spin it by hand. Got It home pulled the head to look for damage, spun by hand and cranked. I put it back together with the old gasket. Started right up. went fishing while waiting for the new gasket, ran great. Anyway after changing the head gasket, I checked my gear oil ALL WATER. I found the driveshaft bearing gone.
Jiggz
Wow! And that bearing is really a PITA to replace. If you have a boat yard nearby personally, I might as well just find a LU to replace it. Where are the roller bearings? Pretty sure they all fell into the clutch and pinion gear assembly which locked the entire unit!
One of the best boating practice is to always check the condition of the LU gear oil at the start of the season. You do not have to drain it all the way. Instead, just keep it in a vertical position and drain only about a spoonful to check clarity. Since water is heavier and stays at the bottom, you should easily see if water is present because it will drain first.
If water is emulsified in the gear oil, then clarity will be really bad, like colored whitish, milky or very light brown. Do not confused brown-dark brown as bad oil especially if you just got done running the LU. With air mixing with the gear oil sometimes it turns into dark brown instead of clear due to air emulsification. There's nothing wrong in this case except you need to top off the gear oil.
Depending how often you go out on the water, I personally check gear oil once a month and I go out about 3~4 times a week.
Simple_Man
I check mine in the spring, mid season, and change it in the fall. What surprised me is that the lower was not making any weird noise. The other thing is that it freed itself on the way home and ran fine for 3 weeks.
Jiggz
With high ambient noise, failure in the LU is almost undetectable until it becomes catastrophic. One experience I have is when I do motor flushing (running motor on muffs) after boating and doing the tie-downs (puts you closer to the LU), one time I can hear the roller bearings on the drive shaft. This is not normal since the bearing is supposed to be dipped in gear oil. This is an indication that the LU gear oil either low or seriously contaminated. And this is a practice I've done eversince.
Anyways, it's really weird it freed itself and ran for another 3 weeks.
Simple_Man
Yeah Mabey longer if I hadn't decided to check the oil. I'm glad my parts motor "LU" is good, It held 10psi for 3hrs.
jerryjerry05
When changing oil.
The directions say: fill until it comes out the vent hole.
Never liked that idea.
So I always fill then fill from the vent hole till it comes back out the fill hole.
Sometimes you can add as much as 4-5 oz.
In all the years of running my 85's never lost a drive.
Simple_Man
I have only had this motor about 5 years, it could have been mistreated before I got it. I was also wondering if I might get a few more rpm's now.
