Hi all,
Took the "New-to-me" 80 Gulfstream Montego out for it's first test-run this weekend. Boat came with 2 Props.
** 21P/14" Diam. Aluminum 3-blade
** 18P/15"Diam. "" "" ""
With the 21 Pitch/14" Dia.... I noticed that at WOT, the RPM's were excessively high (4500-4700) Top speed approx 38MPH
Do I understand correctly that If I change over to the 18P/15" I will achieve a more acceptable, lower RPM (4200Max) at WOT?? Albeit at a lower Top Speed? Is that NOT how it works?
Boat info:
898 Mercruiser 198hp sterndrive 5.0L V8
19ft length Approx 2700 weight
Typically 3 Adults on board
Primary use for run-about/ Tubing
Thanks in advance!!
Mike
Boat info:
Thanks in advance!!
Mike
