I think I have a trim tab problem?
FillupD
I just got my MT1175-60 mobster tabs and they are the same for both sides.
I really need to use my boat tomorrow so I finished putting them on after noticing the potential problem.
Could this be correct, I just don't think so? It will probably work like this but it sure looks like there should be a port and starboard side.
What do ya think? At least it will be a fairly easy fix if I have to change things around.
Re: I think I have a trim tab problem?
you have one bolted on upside down.
roscoe
I think the starboard one look right.
The port one needs to be flipped. Shouldn't take long, 5 bolts on the hinge and 2 on the bracket.
FillupD
These tabs are bent around the edges and the under neath is white, I don't think it can be put on upside down. I guess I could try it until I can get a replacement or shall I try to get by running this way, will it do anything?
This is my first bass boat and I wasn't too happy about the way it got up on plane or how the bow was up when trying to go slow, thought the tabs would help.
roscoe
I guess the best thing to do would be to call the manufacturer and email them the photos you posted here.
Let them make the call.
mippel
Here is a picture from Nauticus web site. Yours do look a little, well different.
FillupD
Thanks for your responses.
Here is the best one:
Hi Phil,
You have 2 of the same tabs and that isn’t correct. Please send me you shipping info and I will send out the proper one. For some reason you received 2 rights and you need a left.
Regards,
Greg Schreiber
8080 Snowville Rd
Brecksville, OH 44141
Mobile#440-832-1301
Ph# 440-746-1290
Fax# 440-746-1291
