I think I just got the deal of a LIFETIME...
SSSuper83
Ok..I will backtrack a little..got the boat running about three weeks ago..went out and the 350 lasted one trip. As I thought it would. So, I have been hunting for a powerplant. I came across a Merc 228 in the paper and decided to drive out and have a look.
Not only was the 228 a 300 hour engine and still fully winterized, but it was in a crate and bolted to a cradle. It's SPOTLESS. Complete from flame arrestor cover to oil pan. Guy says.."you wanna hear it run"?
You bet.
Not an ounce of noise, smoke, or burp. All three serial numbers clearly on engine. Started on the second revolution of the flywheel or close to it. Needless to say, for the price, I was sold.
And then the kicker.."I will throw in the complete transom assembly, all linkage, and Alpha drive for 700"
What??? Yeah..you heard this right. I got a complete powertrain for less than the price of a long block. And not to mention all the wiring from the helm back, Quicksilver shifter, and all the cables. I even got the alpha trim pump. Granted it's not new..but I seen the boat it came out of and the floor and stringers were TOAST. The guy was moving and gave up..needed down payment money on a house NOW.
Not to mention he didnt know too much about boats..
Which brings a couple decisions I have to make. 1. Convert the Sea Sprite to an Alpha drive. Is this possible without removing the transom assembly by just using the drive, Alpha shift cable plate, and trim parts?
2. Sell the Alpha assembly, keep my 898, and buy some interior? :D
Transom ***. and drive look good physically, but its been sitting around a while. What do you think?? I am just happy I might be on the water by Memorial Day weekend!!
SSSuper83
Re: I think I just got the deal of a LIFETIME...
HA I couldnt make this up if I tried..I am still in shock over it.
SSSuper83
I will post pics tomorrow of the pick up bed full of boat parts I have. And BTW..whats a complete Alpha transom/drive worth realistically? I havent dug into it yet, and dont plan to very far. But the cases and other stuff is in pretty nice shape.
45Auto
I bought 2 complete, like new freshwater Alpha transom assemblies off Ebay last year for less than $150 each. Came to a little less than $200 each with shipping. For example, here's one on there right now for $185, 12 hours left and no bids.
http://cgi.ebay.com/ebaymotors/Merc...4261028QQptZBoatQ5fPartsQ5fAccessoriesQ5fGear
There's also an Alpha on Ebay complete with transom assy and a stainless prop for $500, again 12 hours left and no bids.
http://cgi.ebay.com/ebaymotors/merc...at_Parts_Accessories_Gear&hash=item2a0727f6ac
I didn't look much, these are the first 2 that popped up.
I bought an Alpha from a guy here locally that buys and parts out boats for $200, so I could drain and check the oil and pull the top cover to inspect the bearings and gears.
SSSuper83
Here are some pics as promised..I still have yet to get my engine hoist here to get it out of the truck. I plan on seperating the drive from the gimbal assembly to check on everything there but the engine is 100% complete..basically drop in and turn the key.
SSSuper83
Some more..
zbnutcase
Smokin deal if the block isn't cracked.
SSSuper83
This is true for sure..but its been dry for a long time..not a drop anywhere in the risers, manifolds, or block. I guess that is a good sign..no visible cracks anywhere that I can see and I went over it with a fine tooth comb.
SSSuper83
which brings me to another question..can I run riser mounted (alpha) shift linkage with the older drive I have??? Completely different, I know, but I dont want to booger together frankenstein and want to use the best of both since I have all new parts in the #1.
