I think I'm missing a piece in my exhaust...
TimberwolfFXDL
I have an OMC 3.0 (1988-ish) in my Four Winns. I replaced the exhaust boot and gooseneck gasket the other day, and noticed a long pin going through the exhaust down pipe.
I didn't think much about it, until I saw a thread here about an exhaust shutter...
Apparently mine is gone, leaving only the pin? How big of a problem will that be? Forgive the newbie boat questions, but this is my first I/O
Re: I think I'm missing a piece in my exhaust...
Ayuh,... It's no problem at all,...
Til you experince a backwash, or waves hittin' the back of the barge, 'n it hydro-locks the motor....
TimberwolfFXDL
ah great. Where can I find a replacement? Are they a pain in the arse to install?
Ayuh,... They can be bought, Right here at iboats Mega-mall...
Changing it just means goin' back to where you just were...
wire2
If there was a rubber shutter on that pin, and it's come off, you will need to find it, as it will cause an obstruction where the downpipe meets the transom plate. Obstructing the exhaust will mean a loss of power, poor fuel economy and overheat.
See part #35;
http://www.boats.net/parts/search/O...DE 1988/COOLING, EXHAUST & OIL PAN/parts.html
There's a flexible tool made for mechanics, consisting of a lever handle, 2 ft flexible cable, with a grab action hook on the end, that may allow you to get it out without pulling the engine and exhaust.
TimberwolfFXDL
Apparently I can't figure out the system here...
Went to omc sterndrive parts and searched for shutter and flapper, got no hits. If I searched all instead of just omc, there were a few, but nothing that looked remotely like what I need. Is there a part number or specific name I should be searching?
Ayuh,... Go to Engine parts, 'n look at the exhaust system...
Lodgepole
I had a flapper on OMC 3.0 1993 burn/rot off and blocked exhaust, poped back and got hot at rpm. Got parts at marineengine.com James 1 800 209 0624. There are 2 bushings that pop into the exhaust pipe to hold the pin in place. Yours are probably shot if the pin is out. Part numbers my invoice shows are nor clear as to which is which.
Part # description
3855517 bushing, flapper
3852753 913663
pin
That's the way it is printed. Anyway, I'm sure James can fix you up.
