MassillonBuckeye
- Jul 26, 2010
- 400
Yeah.. So I replaced this rusted out fuel sending unit. Worked great(not at first, had to play with ground connection after connecting new sender) but 3 weeks later, gauge now says empty. I know I have at least a half tank. Time to get the volt meter back out. Ugh! Key on and off both show empty. When I turn the key on, I get just the tiniest of jumps at the needle. I'm guessing it's the ground again, although I did a preliminary wiggle after discovering it wasn't working again. I'll update accordingly..
Oh, I'm definitely running a fuel filter heh. Taking the tank out to clean that crap would be a huge undertaking as it is under factory decking. Just a matter of time until the pickup tube gets clogged eh? The float was nowhere to be found. Maybe eaten completely by the fuel?? Although that sender would appear to have rotten away quite a while ago. The boat is an '83 model. Fairly certain that was factory equipment. Starcraft.
