I this wiring ok.
bollie46
Ignition switch went bad and i could not find a replacement locally. Decided to go the toggle switch route as n fun project. I wired it like the pic and it work fine. I am justj concerned that i missed something and burn up a component after the motor runs for a while.
Texasmark
Yeah. The purple (sometimes a red wire with a purple stripe) is 12v after you turn on the ign switch like would go to your fuel gauge or your tach or anything else that needs 12v that you don't want sucking on the battery if the ignition is off. Running lights need to be directly wired to the batt via the light switch because you need them whether your engine is running or not.
bollie46
Thank you sir, i think i must change the topic to help the next guy. I searched for a how to but people mostly did not give good answers when this question was ask previously. Seems like the topic is locked in i can not change it.
bollie46
No Title
Toggle and push button ignition done. I think it looks ok
Texasmark
Nice clean installation. The red protective cover over the toggle switch makes me think about James Bond and the bad guys launching something. Grin
bollie46
Yes still thinking of the best way to label them that will also look good. Any ideas?
