I want avocado trees on my windowsill
JB
When I was a youngster I used to grow avocado trees in my bedroom, sprouted from seeds of Grocery store avocados. :) <br /><br />As I recall, the procedure was to put three toothpicks into the seed and suspend it from the rim of a cup,half in water on a sunny windowsill. In a few days to a few weeks it would begin to sprout. :) <br /><br />I have been trying that for about a year and all I have gotten is about a dozen slimy, rotted seeds. :mad: <br /><br />What am I doing wrong? Did I forget something? Should I sprout them in low light or dark? :confused: <br /><br />Any advice from the green-thumbs out there would be appreciated. :)
Bart Sr.
Re: I want avocado trees on my windowsill
JB....Are you using tap water?With chlorination,flouridation and general mild pollution you may be better off with spring water.I always use it to germinate my seeds.GOOD LUCK!!!THANKFULLY AND RESPECTFULLY>>BART SR.
ob
Growing Avocados from Seed<br />Lee Reich<br />After eating an avocado, it is hard to resist planting its seed. To get the seed sprouting quickly, it needs immediate planting. Indoor gardeners have developed their own "traditional" planting method. This is done by poking three toothpicks into the side of the seed so that it can perch, halfway immersed in water, on the rim of a drinking glass. The seed could also be planted in potting soil, but this misses some of the fun of watching the roots and the shoots grow. <br />Avocado roots, like those of most other plants, need oxygen, so the seedlings would actually grow better in soil than in water. When growing a seedling in water, the water should be changed at least every couple of weeks, before it gets dirty and depleted of oxygen. One way to speed germination in soil is to remove the parchment like seed coat and slice a thin layer from both the top and the bottom of the seed before planting. In water or in soil, set the seed with its base (the wider portion) down. <br /><br />Indoors, avocado plants are often gangly and sparse with leaves. One reason for the plant's gawky appearance indoors is light. Lack of sufficient light causes stems to stretch for it. Another reason is that avocados shed many buds along their stems, buds that might have might have grown into side branches. The result is a plant stretching out for light, sending out new growth mostly from the tips of the branches and shedding old leaves. <br /><br />There are several things indoor gardeners can do to keep their plants more attractive. Most obvious is to give an avocado tree bright light. Also, the stretch for light is exaggerated when warmth stimulates growth, so the ideal spot for the plant is at the brightest window in the coolest room. Beyond that pruning back a stem or pinching out its growing tip stimulates branching by awaking dormant buds (not all are shed) further down the stem. There is nothing that can be done about the shedding of older leaves. <br /><br />Every indoor avocado grower holds out hope for fruit from his or her plant. This is always a possibility, but realistically it is not likely to happen. The time from seed to fruiting under good growing conditions is about a decade. Indoors, this time period is lengthened and plants may never experience good enough conditions to ever flower, let alone ripen fruit. <br /><br />Lack of fruit on an indoor tree is no great loss, because seedling trees rarely produce fruits as tasty as those on commercial trees, which are grafted to good-tasting cultivars. Indoors, avocados are best looked upon as a houseplant that is inexpensive, fun to grow and somewhat attractive. <br /><br />--------------------------------------------------------------------------------<br />(For more information on growing Avocado, see the Avocado Fruit Facts, a publication of California Rare Fruit Growers.)<br />--------------------------------------------------------------------------------<br /> © Copyright 1998, California Rare Fruit Growers, Inc.<br />Questions or comments? Contact us.
snapperbait
JB, you're reminding me of when I did that in first grade.... :eek: <br /><br />As I recall, mind you it has been 25 odd years ago, I believe you have the proceedure correct... <br /><br /> Are you getting the Avacados from a big chain grocery store?... The reason I ask is because so many of the fruits and vegetables now get gassed with chemicals to help them stay fresh longer and so forth which might harm the seed?... It might be that you need a fresh one straight off the tree....<br /><br />My next door neighbor has a green thumb like you would not believe... She has two or three huge avacado trees that she grew from seed... I'll ask her what the secret is...<br /><br />P.S. The avacado tree I started in first grade is still alive and well... :)
durk187
My girlfriends parents are farmers. Once I asked why they don't reuse the corn they harvest for the next years planting instead of buying new. They said the way the new seeds are bio-engineered makes them sterile. The offspring wont grow if you plant them. <br /><br />I don't know the reason or any background on it, but I wonder if the seeds you are getting are the same way.<br /><br />Hope it helps.<br />DC
roscoe
Many fruits and veggies are picked very green, shipped and stored at cooltemps, then "ripened" when needed. They have huge warehouses and they can induce ripening to bananas by filling the rooms with a gas (nitrogen??). <br /><br />It may be your cados are being picked very green also and they are not sufficiently developed or fertilized to produce viable seeds.
JB
Thanks to all for your ideas and advice.<br /><br />I will keep trying. :)
grandx
JB, <br />Take the seed and wrap it in a damp paper towel (not drenched) then put it in a zip lock bag and stuff it in a drawer and forget about it for a few days. I'll almost guarantee it will sprout. You'll have to check on it occasionally as it will begin to mold after a while, but i've generally found it has sprouted about the time the molding starts. I then remove them and pot em. I don't ever recall one not sprouting.
JB
Thanks, GrandX.<br /><br />I will try that. :)
JB
Update: I followed the excellent advice and now have a seed splitting prior to putting out a root and a sprout. :D <br /><br />Thanks again, guys. :)
roscoe
This could be the first NEW YEARS"S BABBY!!!!!!
