iamthunderman
- Jul 29, 2008
- 111
But I have no idea what to look for. Any suggestions?
When you budget for this project don't forget the very large deep cycle battery you will need. Then also don't forget to plan for how you intend to keep this battery charged. Depending on the engine, the alternator may not have enough output to keep up so you then need an on-board charger that you plug in at the dock. And before you ask, NO - a solar panel will not do the job either if you don't have power at the dock. There are no acoustics in a boat so why one needs a mega powered system in a free-air environment is beyond me other than to just "make noise".
Blast your music next to me on the water, and I will help everyone on the lake kick your a...![]()
:0
Just remember, sound carries a long way across the water.
One thing you can never go wrong with in a boat is 2-4 quality 6x9's, preferably 4-ways. As far as subs go, no matter what kind you purchase, as crazy as it may sound, you want your subs 6-10" off the floor firing straight down if at all possible. Personally, I think "marine grade" audio equipment is, for the most part, nonsense. Quality speakers, whether marine grade or not, are usually made from the same materials. I would say that if you take price, quality, and sound all into consideration.....you can't really go wrong with Polk Audio. You could probably spend $1,000 on Ebay and get (4)10" subs, (4) 4-way 6x9's, and (2) amps..........and it would be rockin!!!!! I've got (2) 10" Polk Audio DVC's, (2) 3-way 6.5's, (2) 4-way 6x9's and a 5 channel amp in a bass boat and it sounds damn good!!!!! As far as batteries go, I would go with a Stinger. They are very pricey, but you get what you pay for in that dept. Luckily Ive got 2 deep cycle trolling batteries on my boat.......and you cant fish and listen to the radio all day! It's usually one or the other!!!
Really?...... Really?........ ........
Why on earth would you use a 6x9 if you don't have a space issue? There would be no need.... 6x9's were
Marine head units are "potted" although many use a standard car head unit and keep it dry with good results, marine head units are a requirement in salt water conditions......
Marine speakers are WAY different than a standard automotive speaker. The materials are infact water resistant, unlike those of a standard automotive speaker.
Battery choice is left up in the air, many people have good luck with Optima blue tops, I can't comment on a "stinger" I've never even heard of one, let alone delt with one, personally I don't think you can go wrong with the cheepie walmart brand. They hold up and have a great NQA warranty return.
Bill
As far as "marine" speakers being way different...I'm not sure what you are refering to. "Marine" speakers have poly cones with rubber surrounds, just as you will find in any quality built sub on the market.
