2 days ago I purchased a 1996 15' Dauntless powered by a 2003 40 HP 4-stroke Merc with literally 30 hours on it. I test drove the boat before I got it with 3 people on board-then 2 and still had quite a lag getting out of the hole. I knew the boat was somewhat underpowered but I wanted a BW and after shopping for 2 mths I couldn't have gotten a better deal. The motor literally has 30 hours on it and repowering is not an option. After reading a lot of posts I have pretty much decided on Nauticus Smart tabs. Additionally I'd like to replace the prop. I believe the current prop is a Black Max 13" pitch, 10-3/8" diameter, 3-Blade aluminum prop My primary purpose for the boat is simply for getting from point A to B. After much research my head hurts and I still don't understand the pitch/prop science but I believe I'll have to sacrifice some top-end speed for hole torque. My question is which prop would be the best option?
Thank you for your feedback.
DQ
DQ
