I have a 1972 Evinrude 125283R V4. I would like to add a tell tale to it. I am lining up the OE parts per this thread : http://forums.iboats.com/showthread.php?t=222677
The port mentioned in the thread where it is suggested to tap the hole is already tapped and there is a plug installed in the hole that has a slot for a screwdriver. I attempted to use a really large standard screwdriver but it did not seem to want to budge. Is it safe to heat this with a propane torch or should I use a ratchet with a standard screwdriver bit? I am most worried about breaking the plug if I apply too much torque and having to drill and tap it anyway which is somethign I would really like to avoid.
Thanks in advance.
Thanks in advance.
