artificialreef
- Feb 21, 2009
- 504
Hi folks, my twin 470's had the alternator conversion on them allready when i purchased. Prob is when i run the puppies the alt is flapping around like it needs some more stability. I have a cheap harbor freight arc welder that i am getting pretty good with that i would like to weld an extra support member for the alt somewhere.
I have never welded anything with electronics in it, mostly just utilitarian stuff. If i disconnect the battery is that cool welding on a boat (on a trailer). There doesnt seem to be a very good ground on a trailer. The ground on the welder i think should direct the current to the source ground. I dont plan on burning a hole in the side of the block but might find a an ear to weld on. What do you pro's think?
