2002 merc 5.0 mpi alpha 1 gen 2.Can someone tell me what an iac valve is and what it does? When I took the boat out of the water last season it kept stalling. A couple of years ago we took a ride in the ocean and every time we stopped the motor stalled. I took it to the dealer and the iac was replaced. Now it seems like at idle the motor is loading up with fuel. If I put it in neutral and rev up to around 1200 rpm it is smooth. I put it in gear and it stalls. Any way to check or bypass it? There is not any beeping or alarms sounding. Thank you. RR
