ID Tag Location
Rick K
Hi all,<br /><br />I have a '62 Starcraft Runabout, 14'. Can't find the ID tag for the boat. I'm thinking it got removed or fell off. <br /><br />Anyone have this boat, and know where the tag is?<br /><br />Thanks<br />Rick K
dk990496
Re: ID Tag Location
They are usually located on the back of the boat on the right hand side facing out
Rick K
Re: ID Tag Location
Agggghhh! Someone removed it then. Although I don't see any unaccounted for holes that would have previously held rivets for the plate...<br /><br />Just wanted an HP and weight rating.
dk990496
Re: ID Tag Location
don't have it in front of me right now but if you will click on search and type in starcraft you will find a lot of information there that how i located all my information
roscoe
Re: ID Tag Location
Lots/most small boats built before 1973 did not have a hull id number. Most had only a small manufacturers id plate.
roscoe
Re: ID Tag Location
Lots/most small boats built before 1973 did not have a hull id number. Most had only a small manufacturers id plate. <br /><br />You could contact Starcraft directly.
karrick
Re: ID Tag Location
my 71 Starcraft has a ID plate similar to that of the VIN number plate on a vehicle in the location dk mentioned.
mellowyellow
Re: ID Tag Location
is she Al or F-glass? have seen at least one '72 tri-hull <br />bowrider with the plaque below/front of<br />driver side window. sorry, can't remember the model<br />starcraft it was. been a few years...
Rick K
Re: ID Tag Location
It's aluminum. It's in super shape, so I don't expect it would've just fallen off. I've been all over the boat, so perhaps it never had one. I find that a bit hard to believe though.<br /><br />Rick K
