Re: idea for loosening stuck prop
the real answer is...... destroy the prop to remove it, if the motor isn't worth a new prop, it all could go for scrap metal and salvage. use an aviation style locking nut and run it loose enough for the prop vibration to have an effect. although penetrants can be a help in many instances, they seem to have very little effect on vertical drives stuck in cranks ,or seriously frozen merc props. a prop is much cheaper than a gearcase or propshaft, and it doesn't take much to tear one up, and seriously, I would sooner have one fall to the bottom of a lake than ruin associated parts trying to get one off. I might entertain the idea of taking a new prop and propnut onboard if I were trying that....
