reelfishin
- Mar 19, 2007
- 3,050
I picked up a super clean 16' aluminum boat today but a former owner apparently wanted it to be a 15" transom vs the original 20" transom and took a Sawzall to it. They cut out a trapezoid shaped section 5" down and about 18" across the top, leaving bare wood and metal exposed. I need it to be 20" again, not to mention that the cut hurts the strength of the transom on this boat as the top rail was a heavy gauge aluminum extrusion which is now cut.
I was thinking of making a new wood core, double epoxy coated 3/4" ply, bolting that back in place, and then getting a somewhat heavy gauge aluminum panel bent which will completely cover the whole top of the transom, plus about 6" down on the inside, and far enough down on the outside to cover the cut out panel and to also catch all of the transom wood panel bolts. I'd probably also paint the two panels pretty heavy in between as well as maybe a coat of epoxy to keep water or salt out. I also have to deal with a bolted in knee brace which was originally riveted but is now bolted in with bolts that are about rusted away completely. The lower rivet flanges are gone from the brace, so I may just get that welded to a piece of 3/16" plate and then bolt or rivet it back in place. Then I need to deal with the four 5/16" holes drilled thought the bottom of the boat. The holes are drilled just outside of the keel strip, making sealing them with a rivet impossible. I'm thinking that they may need to be welded closed?
