Idel issues
Hello All,
Let me start by saying I winterized my boat a couple of years again and placed it in my garage...
I have a Mercruiser 3.0 that I took out of the garage after sitting for a couple of years and got her back up and running (New Plugs, New Gas Filter, Oil Change w/ New Filter, Non Ethanol Gas, Sta-bil in Tank) and took her out this weekend, She did great at 1/2 to full throttle. But when I slowed her down to no wake speed or even neutral the motor ran sluggish and/or died. I had to throttle up while in neutral.
My Question is, should I pull apart the carb and clean/rebuild, or should I try running some seafoam (or anything else) through it first? If running seafoam (or anything else) is the suggestion first should I mix in gas tank or slowly add to air intake in driveway and the motor is running?
Thank you for any suggestions!
Bt Doctur
unless your running on hydrogen fuel cell the liquid in the filters. carefully remove and pour into a clear container
