identification help
rallyscort
I recently picked up an older Johnson/Evinrude outboard.I was told that it is a 115.I noticed that the tilt/trim isnt original and was from a 1973 85hp.This motor is an electric shift outboard, and came with the Evinrude controls.It runs like a champ and looks to be rebuilt not too long ago.My question is, is there any identifying parts/numbers that could help me decipher this engine? Normally it wouldnt bother me, but if it is indeed anything lower than a 115hp, it wont be big enough for my boat.I have another 1976 115hp on my tri-hull and these motors looks similar, and the hoods on both say 115.Thanks in advance.
Vic.S
Re: identification help
Normally the model number is on a plate on the mounting bracket. May not be the right number for a "bitsa" though.
There may be a disc on the power head with the model number on. About 3/4" diameter
rallyscort
I found a small silver disk located on the power head.It reads J3342095.
Vic.S
Unfortunately not the model number.
It looks like the serial number. Some people have sufficient info to give you an approx year from that but a dealer should be able to give you the exact year.
