Identify Carb
VeroWing
Can someone here help me identify the carb in this pic? It is on a 24' Grady project I purchased with a 1997 350 magnum engine. Boat has been sitting for a few years, so I want to pull carb, clean it up and put a new kit in it before even trying to start. Thanks
duped
Re: Identify Carb
Carter/Weber AFB 4 barrel. Merc. overhaul kit #809064
alldodge
Re: Identify Carb
Looks to me like a Weber carb. Do you have an enngine serial number?
Re: Identify Carb
Ayuh,.... Looks like my Merc/ Weber Carter clone,....
It's the same carb as the Edlebrock 1409,...
Btw,... Edlebrock parts, 'n kits are cheaper, 'n with more Options,...
This is the Bible for that carb,...... ;)
VeroWing
Re: Identify Carb
Wow, you guys are fast! Engine serial number on tag by starter looks like K278713. Last number may be something else, but rest of numbers are good.
VeroWing
Re: Identify Carb
Thanks for the quick info on carb, and thank you Bondo for the Edelbrock link. Sure appreciate it!
achris
More fish than mountain goat
Re: Identify Carb
Yep, it's a Weber/Carter AFB/Edlebrock...
Look for a symbol in the casting like this
attachment.php
If you see that, it's the Weber...
VeroWing
Re: Identify Carb
Does Edelbrock build these carbs and Weber and Carter rebadge them?
achris
Re: Identify Carb
Original built by Carter, and was called 'Aluminium Four Barrel', hence AFB... Weber bought the license and made the first copies... (what you see on your engine). Not sure how Edelbrock got into them, but they are EXACTLY the same as the Weber....
Re: Identify Carb
Ayuh,.... Carbon Copies,.... Carter AFB Clones,....
VeroWing
Re: Identify Carb
Son of a gun, that's something. I remember back in the old days we'd brag and say we had a Carter AFB, and had no idea what we were talking about.
