Read the sticky and Im not sure which manual to pull? I have a 19' Sylvan Super Sportster. The boats technically a 1991, but not sure if it has a 90 or 91 motor in it. It has a 3.0L mercruiser I\O - I think an Alpha One. I did pull the serial off the outdrive -# 00365956 if that helps. The shop always needs the serial to price parts. Im specifically looking for info related to the tilt\trim (troubleshooting\wiring\etc.), but I want the full manual for future needs. The link would be great..
- My tilt\trim has been needing a rebuild kit, been running up and down very slowly. Last night at the launch it decided to quit for good and my unit is in the stuck down position.
1- I need to know how to manually release and raise the drive so I can trailer it to the shop.
2- The shop quoted about $200 for installing the rebuild kit (does this include solenoids?). Is this a good investment or should I be investing in an enteriely new unit? I will probably try keep the boat as long as possible...
Thanks
Thanks
