Identify part from gear housing...help
goetzco
While taking off the gear housing on my 2005 Alpha 1 Generation II to install new impeller this piece came out. Can't find where it goes, what it is, or even a pic of it in the manual. Can anyone identify what it is and where it goes? Thanks much!
gm280
Re: Identify part from gear housing...help
Not sure what it is on your engine, but I have such a part on my OB. It is listed as an exhaust port baffle. Mine goes in the lower mid section exhaust outlet with three bolts...
hannez82
Part 7 on this exploded view:
http://www.mercruiserparts.com/Show...4.png&inbr=2697&bnbr=250&bdesc=Exhaust+System
There are some differencies depending on installation so you will need to verify that this is the correct one. They usually falls down when the engines overheats or they get (very) old.
Ayuh,.... It's been run, without water flow, that's an ole burnt up Shutter piece...
The Shutters live at the top of the y-pipe...
goetzco
Thanks for the input fella's...figured it had to be from something and just didn't appear...looked at the dry joint exhaust manual and found it...learned a valuable lesson acquiring this boat...14 hours on the motor doesn't mean it's a good deal...lol...gotta laugh about it...crying doesn't seem to help...lol
goetzco
Does anyone know which manual covers the parts and/or removal/installation of the these shutters and the Y pipe? I can't seem to find it in the three manuals I have which are #25...#14...and #37. I have a 2005 Mercruiser 4.3L TKS...thanks.
Ayuh,.... All ya gotta do is pull the elbow aft of the risers, 'n off the top of the y-pipe...
The shutters live at the top of the y-pipe...
goetzco
Thanks Bondo...learning the ins and out of this stuff quick...unfortunately...lol...other than spending money, I'm having fun...
