Identify the thread of this screw from my boat
Lpgc
Boat is a 1996 FourWinns
The screw holds a trim panel to it's hinge and screws into a Tnut, similar screws are used throughout the boat.
Measures 0.185" diameter, pitch seems to be 10tpi.
Caliper open 1"
alldodge
It's a number 8 screw
edit: yes 10
Alumarine
While the OD would indicate #10, if in the 2nd picture the caliper is set for 1" I only count 10 threads per inch. Not sure what it would be then.
since the OP is in the UK
My guess is he has the caliper set to 1cm or 10mm or just past 2x the diameter.
a #10-24 would have a thread pitch of 10.58 threads over a 10mm lenght
bwkre
Looks like 10-24,
Assuming your going to buy the replacement,
Just take it to your hardware store and match it up.
Easy peasy.
alldodge
Upper right corner of first pic shows "in"
These are wood screws
Lpgc
Sorry to mess you all about, the tpi pic above is misleading, my mistake.
I just took 2 more pics...
Caliper set to 1cm (10mm). It seems Scott is correct I had the caliper set to 1cm. It was a few days ago when I took the pics and I'd forgotten what I had it set to, I took a lot more pics at the time but they didn't all turn out as clear, thinking back now I would've set it at an inch but the screws aren't long enough.
Caliper set to 0.5"
It goes through a stainless hinge into a stainless Tnut.
It's a #10-24 x 3/4 oval head screw in 18-8 stainless
Don't need a thread gauge either
Nearly every US boat manufacturer uses coarse thread imperial fasteners. They do not like metric hardware or fine thread
Mc Tool
Wouldnt it be great if there was a system that would standardise this stuff so the whole world could be on the same page 🙄
Marine market may get there in 40-70 years
airshot
Should have been around before WWII, each mfgr had their own threads, nothing was standard....for example....a 1/4" diameter machine screw was available in the following threads, 16, 18, 20, 24, 28, 32, and 36 just as an example. Manufacturing created the standard system we use now to make war production easier and faster..course, fine and extra fine. If you work on old stuff, you will come across some oddball threads, even though they weren't oddball back then...
Mc Tool
Yep , most early manufacturers had their own spec's and nothing else would fit .
Still see the odd thing with whitworth fasteners . An older man I used to work with gave me a (pretty much ) full set of whitworth tools, which whilst not my most used tools they have been handy a fair few times .🙂
Phillips screws were designed by Henry Ford to limit the torque that the line workers could apply. The bit would cam out prior to stripping
