The black spade wire by the thermostat housing is not connected to anything (just a bad camera angle). The pic below is the only pic of my carburetor I could find quickly. Sorry it doesn’t show the choke very well. I have rebuilt the carb several times, so I know it definitely has the ground wire that attaches to the choke housing with a ring connector.
The main reason I’m inquiring about the wires is because I was troubleshooting the ignition system electrical. My volt gauge has always bounced around a lot between 12 and 14 volts while running (very disturbing). I had already replaced the alternator, but still had this crazy voltage fluctuation. I finally resolved this issue. I found that the 10A ignition fuse under the dash had corrosion on one of the connectors. I replaced the fuse and moved it and the wire to a clean unused fuse slot. The gauges now are getting clean power and the volt gauge is reading 14.4 most of the time. The other disturbing part of this is that the same 10A fuse is also responsible for supplying power to the ignition module, sensor, and coil. The engine currently is not running well, so I am going through the wiring looking for more possible issues. Right now, I’m thinking the carb is “gummed” up again and that’s the reason for the poor running especially idling. My 2 barrel carb seems to be extremely vulnerable to issues. I’ve rebuilt it in previous years. This almost needs to be an annual task. The idle is rough now. When I slowly push the throttle up, it hesitates and stumbles and sometimes backfire through carb. If I push throttle quick past the stumble range, it seems to accelerate ok. I’m thinking carb again, but I can’t get out of mind about the thunderbolt V ignition module and whether it’s behaving badly or flaky. What do you guys think?
