Identifying drive/changing gear oil/replacing prop
davemoore
Can someone help me in identifying what unit I have?
Mercruiser I/O 470 1983. I have no idea which one I have but I guess this is pretty important to know. Where do I find some identification marking?
I am confused about changing the gear oil too. I expected to find a drain plug on the lower unit, but it doesn't appear to have one. How do I change the gear oil?
Also, I need to buy a new prop. Don't want to spend big bucks. Any suggestions/recommendations? The previous owner hit something and the prop has slight damage...
Thanks,
Dave
Don S
Re: Identifying drive/changing gear oil/replacing prop
If the engine and drive are actually 83, it would be an R drive, if it's actually an 82, it would be a 1 drive. Not uncommon to have 1 year older engine and drive in a boat because models change at different times.
There is a drain in the bottom of the drive, you just haven't found it yet. Go up to the adults only sticky at the top of this forum, and download manual #6 for your outdrive.
We do have a prop forum here at iboats for prop questions and topics, but minor repairs at a prop shop is the cheapest way to go. Ask your local marine shop about one in your area, or where to ship them to.
davemoore
Looks like the unit is an R. On the nameplate, there is a 1, a 65, and a R. And then another serial number I suppose...
The prop is a 14" diameter, but there is absolutely no inscription on it, so I can't tell what the pitch is.
Thanks,
Dave
