identifying Mercury 150hp inline 6
I have a 150hp Mercury in line 6 thunderbolt ignition outboard. Distributor is shot otherwise the engine runs great.I'm trying to figure out what year the motor is (between1973-77) so i can locate the part. Any help would be greatly appreciated this is what i have for a serial/model number 1150 model# 7057991 ? ? ? ? thanks very much Rick H
Re: identifying Mercury 150hp inline 6
this is what the mechanic gave me ...... 1150 model number 7057991 not sure if this would be the distributor part number ? ? ? ? ?
Thanks for the response Rick H
OldMercsRule
I Dunno why yer usin' a 1150 number. Look at the base of the engine faceing it from the boat. There should be a plate with a number on the transom bracket. There is also a number stamped where the two parts of the block bolt together. I'm not sure but the 1150 probably had the same distributor. My $.02 JR
Laddies
Banned
All inline 6s regardless of HP from 1971 to 79 with a round housing use the same distributer the housing (trigger) is part number 393-3736 in fact if it's the housing that you need a 4 cyl uses the same one with a different plate inside
Chris1956
Laddies, I found a difference in the distributor between my '73 850 and my '77 1500. Although the "guts" of the distributor were identical, the method to bolt it to the block was different. It was easily adaptable, however.
AMD Rules
That is a 1975 Canadian built 150hp Mercury
s/n 7057991
What part of the distributer do you need?
Thanks for taking the time to answer. I am going up to Manitoulin Island on Wednesday to make sure I have the proper serial and model number. I will get back to you though.....
AOMRESP
Eng: 07057991 1150525 Mercury 150 El
Laddies
Banned
Chris, thats why is specified housing (trigger) 393-3736 not distributer assembly
i need a complete distributor for a 1975 Mercury 150hp in line 6 with thunderbolt ignition
AOMRESP
Your parts are still available at a Mercury dealer.
AMD Rules
The distributer body and rotor are over 500 dollars each, at a Mercury dealer. I'd consider looking for an alternate source, such as eBay or private sale if you can.
