Identifying year and hp for a Lower unit 2.3 ratio
Chinpoker
Hi y'all looking for some info to identifying the year and hp of a 2.3 gear ratio L/U that I have mounted to a 64' 850 straight 6 as I'm looking to fit the right size from prop Propulse?
As the guy who sold the L/U to me doesn't remember what year/hp motor it came off of🤔🙄😕
Any help is greatly appreciated!
Chris1956
The inline 4 motors from the 70s had that gear ratio. Not sure why you would need that info. A choice of prop pitch and hub size (likely 4-1/4") should be all the info you need.
jimmbo
The 4 cylinder 65, 75, 80, and 85hp engines used the 2.3:1 case. If used on an in-line 6 the the prop would need to be about 2” higher in pitch than a the original ratio, usualy 2:1 or something close
Your engine has max rpm range 4800 - 5300
Chinpoker
Thanks Jimmbo great info helps me out a lot!
Thank you Chris!
