Identity Crisis
tashasdaddy
took this on trade, suppose to be 18hp, good spark and compression, probably carb gunked up. no tags, no freeze plug.
HighTrim
Re: Identity Crisis
Which lower is on it Tash? Looks to be mid 70s?
tashasdaddy
Re: Identity Crisis
it is not a thru hub,
wbeaton
Re: Identity Crisis
Could be 18, 20 or 25 hp. None would have thru-hub. Looks like its from the 1970's so it could be a 20 hp.
tashasdaddy
Re: Identity Crisis
i can find anything in the old omc site that looks like it.
wbeaton
Re: Identity Crisis
If you can't find it there then it must be later 70's. Although, those motors normally have a blue top where yours doesn't. Definately looks early-mid 1970's to me, but who knows. Could be later. Of course, it seems odd they say it was an 18 hp if it wasn't.
Faztbullet
Re: Identity Crisis
Looks like a 1977 25 hp. What is the carb number if any??
tashasdaddy
Re: Identity Crisis
will pull the carb, tomorrow, the only # i found was 384279 on the recoil stater housing.
marcysibyll
Re: Identity Crisis
With no external coils, looks to be the old style ign system-1973 or older. Powerhead might have been replaced- this one looks like Johnson green, not 'rude blue.
I'd say its a no newer than a 73. could be anything from a 15 to 25 hp. power head. Had a Johnson 20 (roller bearing engine) on a 1959 'rude chassis for years. Got two spare power heads, too. Just in case my 20 takes a dive.
tashasdaddy
Re: Identity Crisis
i went back out with a flash light. got # 314816 and 314817 off by pass covers. the go to a 1968 18 hp they were in the opposite positions, but thats possible.
jethro66
Re: Identity Crisis
I have a 76 20 hp. evinrude with the coils on the outside.Built in peterbourogh ontario,its a late 60's early 70s for sure
F_R
Re: Identity Crisis
I'd say it is a conglomeration of a bunch of mix and match. The decals are 1978, but that's not a 1978 powerhead.
jimmbo
Re: Identity Crisis
The "clamshells" covering the rubber mounts midsection were shaped like that until the 1972 model year. Cowl decal is, as mention before, 1978. What years did the 18, 20, and 25 have a thermostat?
jay_merrill
Re: Identity Crisis
You have a "mix-n-match" motor. The gearcase, exhaust housing, etc. could be from a fairly wide span of years from late 60s to middle 70s. The powerhead is off of a Johnson and the paint color (dark green) suggests 1969 or 1970. The carb may have come with the Evinrude - it looks like it is from a 1972 or newer by the shape of the air cleaner cover.
Short of running down a freeze plug serial number, I think it is going to be hard to figure out if the powerhead is a 20hp or a 25hp because they look identical as far as I can see.
tashasdaddy
Re: Identity Crisis
well i guess i have a true JohnnyRude. may i should put one logo on one side the other logo on the other side of the cowl.
F_R
Re: Identity Crisis
LOL. But I'd suggest parting it out before the cops see it. Looks like a stolen motor chop-shop job to me. It's illegal to posess it.
halmc
Re: Identity Crisis
No, it's illegal to possess it if you know that it's stolen. I also got to say that if there's somebody in the business of chop-shopping 30 year old 25 horsepower outboards, he's in critical need of a new business plan.
tashasdaddy
Re: Identity Crisis
well in Florida, they are not titled or registered, with no id #'s would be hard to prover either way.
F_R
Re: Identity Crisis
Well, I am neither a lawyer nor a cop, but it is my understanding that in Florida it is illegal to possess anything that has had the serial numbers removed. I heard of that when studying up on the law requirements to get a second hand dealer's license. Maybe somebody would like to research this topic and report back here with the facts.
