I've got a 1990ish 2.3 OMC
It's run ok on and off
Lately it runs fine, dies won't start
I've got the timing close to spec at 900 rpm son the muffs, it won't idle at lower Rpms without stalling.
Ignition was upgraded to some sort of Petronix pointless system
Questions;
Does the Petronix require a different coil?
Is 900 to high Rpms on the muffs, will it drop into the 600s under load on the water?
Any ideas where to look for the rough idle problem?
Can the timing belt jump a tooth?
Questions;
