Idle and running problem
Burritto
I have a 1987? 55HP Mercury Mariner that when started idles for about 1 minute and stops. When it does idle, it is very rough. When throttling up, it is not smooth but feels like it is running too rich.<br />It has dual carburation but I need to know where the the adjustments are on the carburators. I do not see anything that looks like a fuel mixture adjustment. Any ideas?
12Footer
Re: Idle and running problem
Welcome to iboats, B.<br />Before attempting to adjust the carbs, does <br />iether one have fuel leaking from it when you pump the primer?<br />If so, this carb has a stuck needle valve.<br />At any rate, get a clean spray bottle, and put some mixed fuel in it .<br />Once you get it started,squirt a few shots into each carb. If performance picks-up, the problem is with that carb. Be carefull.If the engine is 'sneezing' don't attempt this, as it may cause a backfire, and fire in your face :( <br />But it may help you determine if it's missing fuel, or missing spark that is causing the problem.
