ross_larter
- Apr 6, 2003
- 109
Hi, I have a Ford Indmar 351w 5.8l v8 direct drive (1991) raw water cooled.<br /><br />When running yesterday the idle rpm was 1400 when it is normally about 950rpm. It started fine the first time, but when I turned the motor off and tried to restart it, it turned over very slow like a flat battery, after a few tries it started ok and runs fine apart from the high RPM at idle. Also when running the voltage gage is at 11 volts and I think it is normally higher than that.<br /><br />Any ideas?<br /><br />cheers<br />ross
