Idle issues & super low Engine Temp
KnotConnected
Had the boat out for the first time this year! But, now that the lower-units been rebuilt, the engine is giving me $h!t.
1994 Merc 7.4l About 1,000 hours on it. Starts fine, but I need to give it some gas in neutral to get it going, which shouldn't be necessary if it's EFI, right?
More troublesome, it idles down low, at about 500-600RPM (I seem to recall it idling at 800 last year, and reading that 800 is where you want it to be). When I had it in forward idle up the river, it died on me twice. popped it in N and giving it a little gas, it started right back up. It sounds like its running roughly, but its hard to tell on a water-cooled engine that naturally has that rough "blub blub blub" sound anyway.
Additionally, the engine temps were reading almost null. I'm on Lake Michigan, and its freak'ing cold this weekend, but if the engines been running and up at 2500-3500 RPM for a half hour, the should the temps still be within normal operating temps? (wondering if the gauge / sensor is bad)
Any input would be helpful! Thanks!
Re: Idle issues & super low Engine Temp
Ayuh,.... Have ya changed the fuel Filters,..??
Don S
Should be idling at 600rpm, 800 would be high.
When was the last tuneup? Plugs, cap, rotor. Compression test would also be a good thing.
Temp wise could be nothing more than a thermostat stuck open, and with low temp, the ECM will be giving the engine too much fuel.
KnotConnected
Thanks guys. Nope, I got her last August, and haven't change the filters, plugs, cap, rotator, etc.. Probably high-time its done. Will look into it and let ya'll know.
Also, It seems the trim tabs, when depressed any way, pull the running voltage down to 10 or 10.5, which is way lower than anything else on the boat (including the engine trim). Wiring *looks* alright, should i be concerned about this?
Don S
Get your batteries load tested. 10 volts is a dead battery.
KnotConnected
Trim tabs're running off the "Engine" battery, which is brand new. It'll crank the engine no problem, and doesn't have any issues trimming the outdrive up.
