Could someone tell the best way to adjust the idle mixture on a 1985 Suzuki DT40? The manual just says screw the idle mixture screw in all the way and then back it out between 1 1/4 and 1 5/8 turns. A bit vague eh?
Does turning the screw clockwise richen the mixture? I found that at some point on screwing it out the engine starts to cough (sneeze) and turning it clockwise (in) it will start to run rough and smoke a bit.
What is the best way to find the sweet spot? This is a one carb motor...
Thanks in advance
DogScoop
Thanks in advance
DogScoop
