Idle mixture settings
Jambone
Will adjusting the mixture screws in or out affect the higher RPM performance of my 50 hp 4 stroke outboard???
Or are these settings just for the idle???
The motor seems to struggle at about 3300 rpm and I can't get the WOT that I should.
Many thanks
Jim
Dave1027
Re: Idle mixture settings
Only for idle and transistion from idle.
Jambone
Thanks. I see you included a link for ignition troubleshooting.
I am quite sure this is not a fuel problem. I think it might be the cdi unit or maybe the stator. It seems like the timing is not advancing enough at higher RPM?
Thanks for the info.
Jim
