I have an 89 Johnson 90hp. Whenever I try to back the boat off the trailer, the engine dies when I put it in reverse. The only way I can keep it running is if I slam it into reverse. I had a tune up, carbs rebuilt, fuel lines and bulb replaced. It runs great at high speed but idles rough. It seems to help when I depress the choke as it is idleing. Also the overheat horn will go off when I first start up the enging. I had a new water pump installed at the time of the tune up and there is a steady stream of water coming out of the engine. What brand of spark plugs is best? Could and additive be added to the gas to clean out everything? The engine has sat up for several months.
